Weldon fuel pump?
Old Nov 7, 2009 | 07:48 AM
DeanJ's Avatar
Default Weldon fuel pump?
Can I purchase a Weldon 600 from a sponseron here? Also, can it be installed in tank? Thanks , Dean.
Old Nov 9, 2009 | 01:26 PM
Nasty N8's Avatar
No it can not be installed intank Weldon does not rec. it. I do have intank options give me a call.
Old Nov 9, 2009 | 02:24 PM
Jim Craig's Avatar
It is not that it will not operate correctly, it is just that Weldon believes why put it in the tank if there is room on the outside of the tank to mount. IF it were to stop working (as is the case with any electric fuel pump) then its certainly easier to service the pump when it is outside of the fuel tank than if it were "stashed" down inside.
The 600-A & 1100-A draw fuel extremely well as long as the pick up tube is always submerged in fuel -- as it is the case with all of their pumps when mounted on the outside of the tank or cell.
Old Nov 9, 2009 | 03:59 PM
Nasty N8's Avatar
Yes we use alot of Weldon pumps for external they are very good pumps. Will be easy to mount with our new intank setup it will have a whole module with Pump, Voltage controler, filters and wiring all mounted (and easily removable) inside the fuel tank to help keep the pump cool and quiet. We are working on fuel tank systems up to 2500HP. Whole setup will fit and function just as factory.
