42#ers for a H/C car?
Well I ran into a real buy on some used Racetronics 42s. Very low mileage from a trusted individual.
Car= 00 Formula A4/ST3800/3.42 3550 race weight
Ported LS1 heads, 228/236-.588/.578 cam, LSx intake, Dynotechs/merge collectors, electric Wp, all the valve train upgrades, oil pump, timing chain
My questions are:
1. Will these be ok with the otherwise stock fuel system?
2. Will they give a lot of tuning problems? The car will be dynotuned with LS1 edit.
TIA
My questions are:
TIA
They will work but that is a lot of injector for your set-up. I have been running Bosch white 36lb injectors for 3 years and have made many n/a mid 10sec passes without a problem.
Tom
Tom
Tom
Tom
Originally Posted by AL SS590 M6
If I were to shop for new injectors 36s were on my list. But I can get these 42s for a bit less than the 36lbers. That's why I was asking if they would work or not.
As said above they will work....but they will be overkill, and will take a significant amount of tuning from someone who knows what they are doing to make work. Read EZSS' thread about the problems with his JPR motor. I think that his problems were from fuel-wash in the cylinders from a bad tune and too big of an injector.
I have an extra set of 36's if you are interested. The price would be good.
Tom
Tom
Tom
Can you PM or e-mail me the price? I'm very interested as I've not bought the 42#ers yet.
Al
Tuning for the injectors is relatively easy. Just multiply your Injector Flow Rate table. I'd multiply by 165-170% across the entire table as a starting point,
I agree with the others in saying that if you're just a heads/cam car, a 36# injector (30# SVO) is more ideal for you. You can usually find used sets around for 150-200.
If I'm not going to get the 42#ers for $225 then wouldn't I be better off getting the 30#ers in this add?
http://web.camaross.com/forums/showt...hreadid=199774
I confused as to what I really need vs what I could get by with vs what would be best.
Bosch 30#s are listed for $229.95 in the C4 section. These would work in a LS1 right?
http://www.neweraperformanceparts.co...1071762744580&
I am looking for injectors for a TEA stg 2 5.3 and cam with between 228 and 232 on the intake side. These would seem to be the right size?
I am leaning toward the Bosch a friend had some SVOs fail.
http://forums.corvetteforum.com/zerothread?id=690172
Hey Lamar,
30# SVO's *are* Bosch injectors. At Summit (last time I checked) they were $219.
-Andrew (ran SVO 30# red tops on the LT1 car, and currently running them on my LS1 car
no probs )
no probs )
