when do 28.8 max out?
Old Nov 30, 2009 | 10:29 AM
RsSean's Avatar
Default when do 28.8 max out?
Around what horsepower range do the factory 28.8 fuel injectors max out at? I am at 450 rwhp and they seem to be doing fine even with the factory fuel pump. Looking to hit the 500rwho mark before the new year.
Thanks
Old Nov 30, 2009 | 12:35 PM
FICINJECTORS's Avatar
Thanks
they are maxed now. They are 24lb injectors rated at 43.5.. When you run 58psi like in your car they become 28. The max you should run on a stock ls1 injector is 400CHP. If you scanned that engine your duty cycle would be over 100. To support the HP you are looking for you need at least 36 @3bar which will flow 42 in your rail.
Old Nov 30, 2009 | 04:16 PM
RsSean's Avatar
Umm ****. Thanks for your input.
Old Feb 2, 2010 | 07:11 PM
SIC LSX's Avatar
I have seen 430whp-460whp on stock injectors at 98% duty. How is your cam only, stock ls6 intake, stock tb, stock heads, stock block making 450 whp! That's BS
