racetronix?
Old Dec 17, 2009 | 01:59 AM
Mightymike2000ss's Avatar
From: Home town Clive,IA current town FORT BENNING GEORGIA
Default racetronix?
hey guys i understand alot of you are running the dual intake set-ups. but im just a little curious as to what kinda of horse power would the single max out at, in order to have to run a dual intake set-up.
currently im only planning on making only around 500-550 on a d1sc, will the racetronixs be alright to support that?
i would love to run a dual intake but i dont have the time to send it to lonnies, and yes i understand you can fab one yourself................BUT IM NOT GOOD AT THAT STUFF
Old Dec 17, 2009 | 02:54 AM
XtremeDime's Avatar
Should be close to maxed out for your hp goals but itll work. Im debating between the racetronix and doing a custom dual walbro setup.
Old Dec 17, 2009 | 04:58 AM
EPP's Avatar
EPP
I think you'll be just fine at 550 rwhp. Bob
Old Dec 17, 2009 | 01:38 PM
thats all i need to hear, plus im still on 42lbs injectors. when it comes time to upgrade bottom end ill worry about the fuel system.
Old Dec 17, 2009 | 03:23 PM
ss1's Avatar
ss1
I'm at ~550rwhp with a single Racetronix pump and the stock feed line. No problems.
If you want to go with the Lonnies setup you could always look for a cheap core on Ebay and send it to him. That way you would have no down time.
Old Dec 17, 2009 | 05:53 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
I usually recommend 550rwhp as a safe limit for the single pumps, some go higher, but this is a safe number.
If I can help you with a single Racetronix, of a dual system feel free to give me a call.
