69 Camaro LT1
Old Dec 26, 2009 | 07:44 PM
durrettcustoms's Avatar
Default 69 Camaro LT1
Can I use a stock 69 camaro fuel sending unit with fuel injection?
I know I will have to run a return line but I can figure that out just need to know if the sending unit will work with EFI.
Old Dec 26, 2009 | 08:26 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
You could mount an intank pump on the sender & add a fitting to the outlet so it has a mechanical connection.... no worm clamps with EFI.
The factory sender line is not big enough for an external pump.
Old Dec 26, 2009 | 08:46 PM
Well I guess my next question is how can I safely weld a sump on my stock (used) tank.
