Help with LS7 injectors
Old Jan 15, 2010 | 11:39 AM
ss dave's Avatar
Default Help with LS7 injectors
I just purchased the FAST LSXr 102 manifold and my old Bosch 42# injectors don't work.
I want to keep the injectors at 42#'s. Can anyone suggest an injector that will fit?
Thanks
Old Jan 15, 2010 | 05:19 PM
TheGovernorZ06's Avatar
Thanks
yes the gm ls7's will fit...lol i have a set if u wanna buy em?
and they are a 42lb injector
Old Jan 15, 2010 | 10:34 PM
ss dave's Avatar
thanks
the ls7s will fit, but 39's just not big enough
i'd have to run 65 psi to make it compatible
too much pressure= not good
looking at the FAST 50's
but want to keep it at 58 psi if possible, therefore the 42
Old Jan 15, 2010 | 10:59 PM
ss dave's Avatar
I have the Bosch green tops rated at 42"# at 43.5 psi
If I understand correctlly the LS7 are 39" at 43.5 psi, maybe 42# at 58 psi.
My Bosch are 48# at 58 psi-that's what I want-sorry.
Old Jan 16, 2010 | 04:53 AM
ok, gotcha...
Old Jan 16, 2010 | 07:20 AM
FICINJECTORS's Avatar
Thanks
we have ls2, ls3, ls7 injectors that will drop right in. They are available in 42 @ 3 bar exactly the same size as the bosch.. Call me
Old Jan 16, 2010 | 09:34 AM
ss dave's Avatar
Thanks
I had FIC clean up and flowmatch my old Bosch's about this time last year.
Glad to see that you saw this post and replied. I was going to call you Monday
Thanks.
