Fuel Pump Trigger Wire?
Old Feb 1, 2010 | 05:53 PM
Sweet71's Avatar
Default Fuel Pump Trigger Wire?
Anybody know what color the fuel pump trigger wire is under the backseat at the bulkhead? Thanks! 2000 Z28
Old Feb 2, 2010 | 12:06 PM
code4's Avatar
It's green at the pcm, i don't remember if it stays that color back there.
Old Feb 3, 2010 | 12:17 AM
nemss1's Avatar
i think it stays green all the way from what i remember
Old Mar 8, 2010 | 11:39 PM
XtremeDime's Avatar
Bringing this one back. How would the trigger wire go all the way back if the relay is in the kick panel?
Old Mar 9, 2010 | 05:51 AM
koolaid_kid's Avatar
In the strictest sense, it doesn't. The term trigger wire relates to the relay, which is up front. However, if I were to put an aftermarket fuel pump on, I would use the power wire from the original relay to the pump as the trigger wire for my new relay. (I would install a new wiring harness to handle the increased current demand.) Hence, the original power wire to the pump becomes the trigger wire to the new relay for the aftermarket pump.
Hope that makes sense.
