victor jr
Old Feb 12, 2010 | 03:50 PM
WVJEEPERS's Avatar
Default victor jr
Ive read a great deal about these intakes, but all the dyno runs wernt on stock ci engines.
Would it help or hurt a 5.3 with 11.1 CR, mildly ported heads and a .600 lift cam? Right now it has a stock ls1 intake/throttle body and i would probably go to a 85 or 90mm throttle body when swapping the intake.
Old Feb 15, 2010 | 09:33 PM
InsaneDomestics's Avatar
I would think you would definitely see a Gain over the Stock Intake. I'm sure Edelbrock wouldn't come out with something that flow worse than a Stock LS1 Intake. Just my opinion though.
Old Feb 15, 2010 | 09:44 PM
hivoltagedriver's Avatar
It will make more power... up top. You are probably going to loose some low end torque. You would also probably want to consider a cam that would compliment that intake. If I remember right, the Vic Jr is built to make power from 3500-7500rpm.
