Stock 28lb injector question
Old Feb 17, 2010 | 09:27 PM
km346's Avatar
Default Stock 28lb injector question
Hey guys, I was wondering what the difference is between the 1998 12554271 injectors and the 01-02 12561462 injectors? Ive read in one of the high performance ls1/ls6 books that both PN's flow exactly the same at 4 bar, but then ive read on the web that there might be a slight difference... im not sure what to believe. Is it safe to use the 01-02 28lbrs in my 1998 car?
Thanks
-Kyle
Old Feb 17, 2010 | 10:54 PM
FICINJECTORS's Avatar
Thanks
-Kyle
there is no difference. The 271 injector came with a Buna o ring, the later 462 came with viton o rings . The base injector is the same, and you can put them in a 98
Old Feb 18, 2010 | 05:54 AM
blue98Z's Avatar
+1........FWIW I'm running 01 28#ers in my 98 if that helps ya any.
Old Feb 18, 2010 | 08:33 PM
km346's Avatar
Thanks for the responses!
I just wanted to make sure i can bolt these puppies up and not have to worry about any fueling issues.
