Magnafuel pump broken???
Old Mar 1, 2010 | 07:21 PM
Snyper's Avatar
Default Magnafuel pump broken???
So tonight I wired up my pump as per magnafuels instructions and went to test it and alls I heard was a click inside the pump. After trying it to or three times I then applied direct power to the pump and still got the same result. Just a click inside the pump like youd hear from a relay.
Old Mar 2, 2010 | 11:09 AM
Nasty N8's Avatar
Never seen one lock solid but Send it to MagnaFuel they will fix it. Great guys and will get it back to you ASAP.
Old Mar 2, 2010 | 01:02 PM
Snyper's Avatar
They told me to take it apart to check for debris so I did and spun the gears by hand..didnt see anything in there put it back together and just for ***** applied power to it and it worked again...any ideas? They said I could either send it in to have it looked at or just try it and see if it happens again. Something really small could of gotten in there and when I spun it by hand freed it up maybe?
Old Mar 2, 2010 | 07:46 PM
00bluews6's Avatar
if it works it works but i would hateu to lose pressure during boost
Old Mar 3, 2010 | 11:10 AM
Snyper's Avatar
It locked up again. When I took the cover off the retainer is metal and it seemed like it might be too big..if I put the cover on and and tighten the bolts it works..as soon as I tighten them now(and just enough to seal) the pump locks...
Old Mar 3, 2010 | 12:21 PM
Nasty N8's Avatar
Send it to MagnaFuel before ruining the pump they will fix it and get it back to you. They are really good guys and easy to work with.
Old Mar 3, 2010 | 02:31 PM
Snyper's Avatar
yeah I did that this morning. I have a warranty until September.I hope the problem gets solved. Im tired of being soaked in gas.
