Should i just do a delete?
Old Mar 7, 2010 | 11:24 AM
FireBirdSoldier's Avatar
Default Should i just do a delete?
Im sorry if this is not the right section for the post...didnt see a more suited one...but anways. I recently purchased a 2002 T/A. And the service engine light came on the code read both cats. And bank 1 sensor 1. The guy at auto zone didnt know shi*. So i assume that is the o2 sensor upstream of the driver side cat?? And for the cats should i just do a delete or would it be worth replacing? There is no emission laws here.
Old Mar 7, 2010 | 05:49 PM
ZL1Killa's Avatar
bank one sensor 1 is the oxygen sensor that you need for your car to run Closed loop.
Old Mar 10, 2010 | 07:12 PM
Noone has an opinion if i should do a delete or not?
Old Mar 16, 2010 | 11:00 AM
Darksol's Avatar
Don't delete it. Fix it. https://ls1tech.com/forums/pcm-diagnostics-tuning-7/
This might be more appropriate spot for it.
Old Mar 16, 2010 | 11:37 AM
Nasty N8's Avatar
Fix it properly you may cause more problems.
