Diaphram on fuel rail?
Old Mar 8, 2010 | 10:27 AM
jkkaz's Avatar
Default Diaphram on fuel rail?
What is the diaphram looking thing on the fuel rail at the supply line? This is for a 99 vette so I assume the regulator is in the back as part of the filter so is that diaphram looking thing needed?
I ask because I was going to install a set of aftermarket rails.
Old Mar 9, 2010 | 05:12 AM
LS1MCSS's Avatar
It's a fuel pressure damper. It keeps the pressure steady at the set pressure instead of having pressure spikes and low points as the pump turns.
Old Mar 17, 2010 | 08:33 AM
Ryneman's Avatar
I have also just bought some aftermarket fuel rails. A complete kit, like yours jkkaz. So it is the fuel pressure damper. I assume that you don't need this??? Also, when installing aftermarket fuel rails, do you need to install an aftermarket fuel pressure regulator?
Thanks
Old Mar 17, 2010 | 01:13 PM
jkkaz's Avatar
I don't know how critical it is to have that damper. I've never run a car with the return line so far away from the fuel rail. My plans for installing the aftermarket fuel rail are going to wait until I get a regulator and install a return line at the fuel rail. My head cam swap is still being finished up so the fuel rail part is one of those things on my "to do" list.
