Back to the drawing board
A: Keep the 1 walbro gs340 pump in tank and run new walbro gsl392 or bosch 044 inline pump. Y together. In tank pump will be on a Hobbs switch, each will have a relay and a pre pump filter and 1 filter after the Y. This would require running new wiring for the new pump, etc.
or
B: Eliminate intank pump and block off. Run 1 magnafuel 525 pump. Less wire, not heating fuel. But is this over kill. Not sure what flow rate I need....is 77gph (462 lbs/hr) enough? There are other pumps for less money
Both systems will Y off before the engine to 2 -6an lines to run to the back of each rail and crossover with -6an line in front. Then from the driver side rail it will run into a FPR and from there back to a return line to the tank.
BTW the motor is a SC LS2 making 650-700rwhp. Some say that 1 bosch 044 inline might be good enough but that might be right on the border???
you think the one bosch 040 would be good enough? that pump is 300 lph
http://www.boschfuelpumps.com/
I just think the 1 in tank bosch might not be enough
what I am wondering is, what is a better set up, a dual pump, 1 intank - 1 inline system or single inline pump system.....forget about cost becuase they are less then $300 between them. thanks
Need to get my tank back and then will map out the rest but should I replace my current return line which is 3/8 OD 5/16 ID alum line with -6an or even -8?
