Question about fuel in intake and TB
Old Apr 20, 2010 | 12:02 AM
corpserodeo666's Avatar
Default Question about fuel in intake and TB
There is a good amount of fuel in the intake and the elbow and even in the throttle body. I just don’t know what it can actually be. The car is also FI and it has a Vic Jr. with a Sheetmetal elbow. I also have a Nasty Performance fuel system with a Magnafuel pump. Can it be that its running rich? or something else all help is appreciated. Thanks again.
Old Apr 20, 2010 | 07:11 AM
Old Geezer's Avatar
R U running a boost referenced fpr?
Old Apr 20, 2010 | 11:42 AM
Yes I am it is coming right off fuel rail.
Old Apr 20, 2010 | 02:33 PM
Could it be a sticking injector?
Old Apr 21, 2010 | 08:29 AM
Old Geezer's Avatar
Question Check the..
vac line to the FPR. Have fuel in it?
Old Apr 21, 2010 | 03:02 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
If you have a big cam, there can be reversion in the intake that will blow fuel back up into the intake.
Typically fuel is not noticible as it readily evaporates. Usually it is oil vapor from blowby that is introduced from the breather into the throttlebody.... or if forced induction, oil from the supercharger/turbo can also get in the inlet system.
Are you positive it is fuel only & not a mixture of oil?
Old Apr 21, 2010 | 03:38 PM
It's a little darker in color I'm thinking I have seen it before it might have a little oil in it since I don't have a vac system installed. Ill check the vac line also to see if it has anything in it.
