Trap Door Mod
Was looking to see how to do this and was wondering where the door was located exactly. I found this at Michigan F-Body.
I vote we make a sticky of a good trap door writeup. Seems like it's REALLY useful information...
changing the last sparkplug would also be easier if you had a hole in you fender, it would be like a 10 sec job then
and also, when you install a performance fuel pump you should be cleaning the tank, to make sure there is not **** in there. but you can not do that if you do the trap door method. racetronix had a problem before when people where sending in broken pumps with the filter sock brown
anyway, it is your car, do whatever you want. i am just trying to give you a suggestion
