Whos running the Siemens 57# injectors??
Old Jan 8, 2004 | 06:39 PM
BIGBOS's Avatar
Default Whos running the Siemens 57# injectors??
I need more fuel delievery on my car, going to a twin 340 setup in the tank, and I'm currently using 42.5LB injectors and a CAS rising regulator.......
The motor is a 6.0L 372c.i. Iron block setup, going to see around 15-16psi, will the 42.5's cut it with the twin 340's??
I want to step up to 57's, but my local speed shop is saying that they are having problems tuning with them......
Old Jan 8, 2004 | 08:48 PM
MIGHTYMOUSE's Avatar
i didnt have any problems tuning my mototron injectors. (60#)
i use the same regulator as you.
Old Jan 9, 2004 | 01:27 AM
BIGBOS's Avatar
Your using LS1edit correct?
I don't understand why the 57's would be a problem........
Old Jan 9, 2004 | 09:24 AM
smokinHawk's Avatar
there is a guy on here with a convertible 409 iron block with a vortech supercharger pushing around 550 rwhp
he had to go to a dual pump, casue one walbro didnt supply enough for his iron block.
not sure what injectors he was using before he switched to the 57's
anyway 42's can support about 600rwhp if they have enough pump.
Old Jan 9, 2004 | 03:36 PM
bigbos, yes i use edit.. this is a quick shot at it but i would put the flowrate table for those injectors at 7.4 across the board... that should put you sligtly negative l trims.
Old Jan 9, 2004 | 03:59 PM
BIGBOS's Avatar
I will keep that in mind when it comes to tuning.....
Old Jan 9, 2004 | 04:38 PM
but i would get the mototrons
Old Jan 9, 2004 | 10:40 PM
BIGBOS's Avatar
Where can I get a mototron 60# injector?
How much do they go for, and you have had success with tuning these?
Old Jan 9, 2004 | 11:38 PM
i ran them at 50psi at idle (@60 at 0 vaccum) and they held a misfire free idle at 1.6milliseconds... which is quite impressive to me.
http://www.mototron.com/prod_minifuel_long.htm
drawbacks are they do not come in matched sets and they do not give returns.. but mine did work great and were showing some serious flow capability over the 42# svo.
Old Jan 10, 2004 | 11:06 PM
Texas Terminator's Avatar
i have the 57's with the stock intank and an inline. FP will maintain above 50PSI. IFR ended up at just over 6.0. this is with 10PSI boost.
Old Jan 12, 2004 | 01:26 AM
BIGBOS's Avatar
I don't like the fact that those are not flow matched, I guess if I have to I will give the 57's a try.....
Maybe my 42's will support, I just want more than enough fuel.........
Old Jan 12, 2004 | 08:32 AM
onfire's Avatar
Coal Mining Director
Rob Raymer is running the 57's. Also Andy at A & A is running the 57's in a few cars.
Old Jan 12, 2004 | 09:49 AM
KraZy's Avatar
I bought flow matched 57# injectors at Racetronix. They have yet to arrive, but I will let you know how it goes.
Old Jan 12, 2004 | 12:40 PM
BIGBOS's Avatar
Keep me updated, make sure to post in this thread.........
Old Jan 12, 2004 | 02:26 PM
NA$TY-TA's Avatar
BOS im going to order the 57's from Racetronix's and run dual 340 intanks. Ill keep ya posted.
Kyle
Old Jan 12, 2004 | 02:34 PM
BIGBOS's Avatar
Yea, thats the identical setup I was planning on doing, that or a 420inline
Old Feb 10, 2004 | 02:24 PM
BIGBOS's Avatar
TTT on this thread......I'm deciding on 57's or the mototrons......
I need some more tuning tips with these 57's for all of those who are running them............
Old Feb 13, 2004 | 04:04 PM
Terry Burger's Avatar
Want to trade my new 50#s for your 42#s + a little cash?
Old Feb 13, 2004 | 04:15 PM
BIGBOS's Avatar
I already got the 42's sold, but if it falls through I might consider......
Old Feb 13, 2004 | 05:27 PM
NA$TY-TA's Avatar
BOS,
I am going to order my 57#s next week so ill keep ya posted since my motor wont get here till next month. I went twin 340 intanks, Billit rails, -8AN feed, stock return with a Boost ref. reg.
Kyle
