shouldi change the injectors
Old Jan 8, 2004 | 08:10 PM
Q8CamaRo's Avatar
Default shouldi change the injectors
my frined has a 1998 camaro ss installed a custom cam 588/588 228/228 112 lope sep.
LS6 intake maifold, GMS maf sensor, GMS air lid,under drive pully, slp oil pump,
slp double roller chain , Z06 clutch, 3.73's gears, hpp +3
now i eanna ask if i should change the factory injectors
if yes pls tell me whatkindof injectors shoould i install
and thanks
Old Jan 8, 2004 | 08:14 PM
01PewterWS6's Avatar
Since its a 98 you might not have to i think they came with 28.5s like the 01-02s
https://ls1tech.com/forums/generation-iii-internal-engine/126553-fuel-st2-heads-tsp231-237-a.html
Old Jan 8, 2004 | 08:31 PM
Dave00C5's Avatar
and thanks
The 99-00 cars had the 26lb injectors so your good to go with the 28's in it unless you get over 450rwhp.
Old Jan 8, 2004 | 08:33 PM
He should be fine until he gets some heavily ported heads and a bigger cam or other mods like nitrous.
Old Jan 8, 2004 | 09:58 PM
Mike98WS6's Avatar
For a 98 he should be fine up until u past say 430-440 rwhp. At that point I would get bigger injectors and maybe an in line pump too. I went with the SVO 30 lb. injectors just in case I put a bigger cam in.
