-8 feed line help
Old May 8, 2010 | 12:29 PM
LSXFORMULA99's Avatar
Default -8 feed line help
what would i need to put a -8 line from the tank to the fuel rail? any pictures?
Old May 8, 2010 | 02:40 PM
Aster's Avatar
You wanting to try and use the stock rails or getting aftermarket rails too?
Old May 8, 2010 | 07:57 PM
stock rails for right now. just want to do it since i have the pump out now. i know what i need for the fuel rail. just need to know what i need to do for the tank
Old May 8, 2010 | 09:41 PM
Aster's Avatar
Aeromotive makes a quick disconnect to connect the outlet on the stock fuel bucket to a -8 O-ring boss female, the part number is 15118. You can then get a -8 ORB to -8 AN fitting like the Russell 670700 connector. That will let you mount on to the -8 AN hose end up to the front.
You will need to do something though for a return to the tank since the stock feed line has the return built into it near the fuel filter which goes back to the bucket and regulator.
Old May 9, 2010 | 08:32 AM
damn i didnt know that. sounds like a pain in ***
Old May 11, 2010 | 10:48 PM
sschoeffler's Avatar
The quick connect you need for the front line is about $40 bucks. Seems a bit costly for me when it would get changed over to an aftermarket rail later. I'd just get your rails and line and do it at the same time.
Old May 12, 2010 | 01:26 PM
yeah thats what i will prolly do
