need advice on new injecters
Old May 8, 2010 | 01:34 PM
kellycd410's Avatar
Banned Scammer
Default need advice on new injecters
Im running my new 383 stroker with st 2 ls6 heads and i changed to the ls6 intake and whatever sizestock ls6 intake injectors is what im running now,i think they are 28lbs , my car has been tuned however i did i data log yesterday and my duty cycle on my injecters spiked to 128 (6100 rpms) i obviously need bigger injectors, what size should i run to maintain the best performance and fuel economy as well, and is a new fuel pump/fuel rails also going to be needed? please help thanks
Old May 10, 2010 | 01:30 AM
LS1-450's Avatar
42#ers w/ PCM injector setting mods required + Walbro 255 lph fuel pump. Stock fuel rail is OK.
Old May 10, 2010 | 02:44 AM
Squirts11's Avatar
42s should be fine. Make sure you don't drive around with them installed unless the PCM has been calibrated, otherwise you could wash the cylinders with excess fuel
Old May 10, 2010 | 06:06 AM
69LT1Bird's Avatar
Call Jon at FIC and he will get you the right size and the easiest to tune injectors.
http://fuelinjectorconnection.com
