possible to test a used gs340?
Old Jan 11, 2004 | 03:40 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default possible to test a used gs340?
I have an old Racetronix single intank setup lying around, but I'm not sure if the pump is good, how can I test it?
Old Jan 11, 2004 | 08:37 PM
mike72678's Avatar
I tested my pump before I installed it just ny hooking up the 2 main wires in the sending unit to it (without it installed) and then turned the key (without starting it) and just listened for it (for about 3-5 seconds so you don't burn it out) . But , I installed my pump through the trunk by cutting a hole .
Old Jan 12, 2004 | 10:45 AM
Black LS1 T/A's Avatar
Moderator
Just to test it operates (I don't know how it would be verified as optimal), couldn't you sit it in some gas with the wiring connected and put the other end of the wires to the posts of a battery?
