Red or Greentops for me?
Old May 17, 2010 | 12:17 AM
hitmanws6's Avatar
Default Red or Greentops for me?
Hey guys, I'm looking to run a H/C setup in the future on my LT1. Heads will be similar to LE2s, cam will be a 236/242 .557/576 112. Which injectors would work the best? Is there another brand I should consider?
Old May 17, 2010 | 04:49 AM
GA95DCMSS's Avatar
Do you plan on going any further than a H/C Setup in the future? If not, I'd recommend 30# injectors. If you plan on going farther, 42's.
Old May 17, 2010 | 06:55 AM
toomchz4u's Avatar
Get the 42's. More injector than you need now won't hurt anything and if you change your mind about your setup you probably can use them in the future. I bought 30's then decided to get a bigger cam and port my heads so I had to sell my 30's and get 42's.
Old May 17, 2010 | 10:51 AM
hitmanws6's Avatar
Maybe a stroker build someday. For now I just want a 355 with a 58mm TB, ported intake, ported heads, that cam and full bolt ons
Old May 17, 2010 | 10:37 PM
conde'strans's Avatar
42 green tops and you won't regret it!
