Tell me about 42 pound injectors
Upgrading your injectors are only going to help you if you've modified your engine to the point that you need the extra fuel flow (big cam, high flow heads, turbo, supercharger, big nitrous, etc). 42# injectors are pretty hefty and if you don't take care of tuning and you don't have the requirement, you would be running pig rich.
Originally Posted by Zanthius
Does it really HURT you to run larger injector than required?
with a large injector, it takes more skill to get idle correct, ect.
That is why you don't see 42# injectors stock in everything, as they are used in the lightnings, and 03+ cobras only.
Ryan.
