Fuel pump questions...
are all fbodies fuel pumps the same 98-02?
will a 99 fuel pump fit a 1998?
what else should i learn about this and what else should i do?
thanks
98 is different & will not work properly in the 98 tank.
If your sender is badly rusted, look for a good 98 sender core at a junkyard or ebay & I can set you up with a new performance pump kit to correctly fit the sender.
