fuel pump pressure
Old Jun 3, 2010 | 07:16 PM
Richard 72 GMC's Avatar
Default fuel pump pressure
Just purchased a 6.0 lq9 that will be going into a 72 suburban. Can an in line pump be used instead of an in tank? If so what pressure/gph do I need? The motor is stock.
Old Jun 3, 2010 | 09:22 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
You need 58psi to match the factory program for your motor.
a 255lph pump will work nicely.
You will need a regulator to control the pressure, the pump will not control the pressure.
If you are interested in a pump with harness & fuel fittings (or a complete line kit) , I can get you the parts you need. Feel free to give me a call.
Old Jun 9, 2010 | 03:12 PM
434strokergt45r's Avatar
Banned Scammer
about 43lbs is fine
