Fuel filter
Old Jun 10, 2010 | 02:29 PM
MTBSully's Avatar
Default Fuel filter
what are you guys running for fuel filters? I recently aquired a 2000 camaro ss and since they are cheap im going to do a fuel filter with my full tune-up. Do you guys just run to the local autozone or advance and pick up whatever they have? Are there some brands i should look out for? Thanks
Old Jun 10, 2010 | 02:55 PM
MeentSS02's Avatar
Kleeborp the Moderator™
When I ran a stock-type filter, I just used whatever they had a Vato Zone. The only thing I might recommend is picking up a set of the various brown o-rings they offer (I think it is a Help! type of item with various sizes for fuel-injected applications) that they should also have in case the one currently on there isn't in good shape when you take the current fuel filter off. It'll be on the side with the hard line (where you have to unscrew the fitting to get it off).
Old Jun 10, 2010 | 03:31 PM
ROCNDAV's Avatar
That's a good tip about the Oring.
