high vol. or high pressure Racetronics ???
Old Jun 20, 2010 | 12:44 PM
Lacajun's Avatar
Default high vol. or high pressure Racetronics ???
Plan on adding a nos kit....so I am upgrading my fuel pump....do I need High Volume or High pressure
Old Jun 20, 2010 | 12:47 PM
97lt1stangstomper's Avatar
you need volume your stock pressure is good
Old Jun 20, 2010 | 01:18 PM
Lacajun's Avatar
Default thanks
thanks will order 1 in the am
Old Jun 20, 2010 | 09:53 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
The pumps are high volume, but also rated for the higher LS1 pressures, so in effect it is high pressure as well. Remember most fuel systems (and pumps)were rated for use at 43psi prior to the LS1.
I have these kits in stock if interested.
