siemens 60# to long
Old Jul 8, 2010 | 02:52 AM
Busy Mopper's Avatar
Default siemens 60# to long
i have these injectors that im guessing will require pigtails to fit on the fuel connectors. my question is will this be a problem with mountin the rails? or do i need to shim them... i would like to run these injectors
Old Jul 8, 2010 | 10:59 AM
Nasty N8's Avatar
They will fit fine on an LS1/6/Fast92/...intake???? I ***-U-Me you are referring to an LS2/3/7 then yes you will need spacers and pigtails. There are correct connector injectors available.
