high HP fuel system on low HP setup?
Old Jul 13, 2010 | 05:32 PM
transaman98's Avatar
Default high HP fuel system on low HP setup?
I have been tossing the idea of picking up:
2 Walbro 340 intank fuel pumps
Walbro fuel pump install kit
Nasty Performance hotwire kit
Nasty Performance Billet fuel rails
MagnaFuel billet fuel pressure regulator w/boost ref.
MagnaFuel billet stainless steel fuel filter
Aeroquip -8 braided stainless feed fuel line
My car doesn't make anywhere near the kind of power that this fuel system can support but I am piecing together a turbo kit and was curious if anyone could tell me if and why it would be a bad idea to install the fuel system prior to the turbo setup and just run my 30# SVO injectors in the mean time.
Old Jul 13, 2010 | 05:34 PM
Meemperor's Avatar
It would be fine. If you had a proper kit from Lonnie. Your hobbs switch would never activate, so it would run like you only had 1 pump anyway.
Old Jul 13, 2010 | 07:19 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
One of my dual pump kits will work fine in yor application. You can either disable 1 pump until you need it, or run the boost activation switch, that will prevent it from operating without boost.
Feel free to call if you want to discuss your current & future needs.
