fuel line
Old Jul 14, 2010 | 02:57 PM
00bluews6's Avatar
Default fuel line
what fuel line is everyone using i need -10 and -8 im going to run the magna fuel 750 pump
Old Jul 14, 2010 | 04:29 PM
Jim_PA's Avatar
I wouldn't recommend Anything rubber, unless you want to change it out every 5 years.
I had Aeroquip socketless on mine for about 5, and the outside casing is starting to look cracked and dry-rotted. Around the fittings, they casing is starting to blister off. It's pretty frightening actually.
I would say steel (probably not possible at that size...) or anything with a teflon inner core, but that's just my opinion
Old Jul 15, 2010 | 03:07 PM
Nasty N8's Avatar
Give me a call I can set you up with what you need.
Old Jul 15, 2010 | 03:17 PM
Bad Blue WS6's Avatar
Nate's the MAN!!!!
