better for 100-150 wet shot?
Old Jan 19, 2004 | 05:24 PM
NOTFAST's Avatar
Default better for 100-150 wet shot?
Trying to decide whether a boost-a-pump or 255lph inline would serve more function --
Im trying to be extra safe even though a 150 shot would probably work on stock fuel pump/injectors...
i have a 98 ss with simple stuff and then a TNT kit...
-- thanks --
Old Jan 20, 2004 | 09:36 PM
silverTA's Avatar
GO with 255lph
Old Jan 21, 2004 | 10:10 AM
Nasty N8's Avatar
A boost pump is not going to help much. You will only get the same flow the stock pump can flow you can not pull any more through it. I would rec. a Walbro GSS340 intank pump it is 255lph and you will get all that fuel.
Nate
Old Jan 21, 2004 | 11:23 AM
NOTFAST's Avatar
but dont you have to drop the axle to change intank pumps?
Old Jan 23, 2004 | 04:21 PM
xQuickSilverx1's Avatar
wouldn't a 255lph inline pump work?
Old Jan 27, 2004 | 12:43 AM
35th SS's Avatar
just cut an access hole in the back to get to the pump.been there done that.on 98 you will need to drop the rear.100shot wet on stock pump you can get away with it.150 your rolling the dice.dont do it.
Old Jan 29, 2004 | 08:07 PM
GrapeApe's Avatar
a 255 should increase the volume but not the psi
Old Jan 31, 2004 | 02:57 PM
Navy David SS's Avatar
I also have a 98. One think nice about the 98, RaceTronix makes a direct drop in for our year. One of the upgrades this year will be this new fuel pump and 150 shot
Bought mine from http://www.thunderracing.com/index.c...yid=1080#T1844
David
Old Feb 4, 2004 | 05:55 PM
35th SS's Avatar
Sounds like a plan to me.heard the racetronix setup is nice and easy to install.running the walbro setup on both cars.no problem here.
