Horrible Gas Millage
Old Jul 19, 2010 | 03:04 PM
jugz ss's Avatar
Angry Horrible Gas Millage
Well after I did the cam swap and all that good stuff. I dicided to see what millage I would get to a full tank since I never checked and I see most people get close to what GM says it should. So I fill up, reset trip milage and drive away. After driving both street and highway. Gauge light on. Its only at 178.xx . Thats not even close to what gm says just street. I'm thinking theirs something I can do. Any help would be apreciated.
Oh and the car was tuned about a month ago.
Old Jul 19, 2010 | 03:15 PM
KevinR's Avatar
Man, on a good week I get right at 200 miles per tank. The ms4 is a healthy cam, so I think that's the nature of the beast when it comes to big cams.
Old Jul 19, 2010 | 03:20 PM
jugz ss's Avatar
Yeah I just tought it was a little off. But I guess it could be the cam. I just talked to my tuner and he said it was because of the cam.
Old Jul 19, 2010 | 03:23 PM
KevinR's Avatar
Before I put my cam in, the best I got out of my car was 299.8. I wanted to see if I could get 300, but just missed it. But yeah, now it averages right at around 200. It sucks, but that's the price we must pay, my friend.
Old Jul 19, 2010 | 03:24 PM
99TransAmLS16Spd's Avatar
You are running the MS4, correct? Welcome to the world of crappy gas milage...
I have EFILive, and spent quite a bit of time getting the part throttle tune as close as I could when i had that cam. A/F ratio was always between 14.5-15.1:1 when cruising, usually dead on the nose at 14.7:1. I considered myself lucky if I baby footed highway miles and achieved 17mpg with an M6.
I truely believe those with huge cams and claim they are making 25+mpg simply don't calculate their milage correctly.
My only advice is if you have a 6 speed - don't assume that driving in 6th at 40mph will save you gas. Drive at an rpm where the engine feels responsive and not on the verge of bogging down
Old Jul 19, 2010 | 03:32 PM
jugz ss's Avatar
Yeah it is a ms4 and I do have a 6 speed. During the time I was checking the milage I would be around 5th gear at around 1500rpm doing 40-45. I would hit 6th in the highway and keep it from 1500-2000rpm but I would be over the speed limit.
Old Jul 19, 2010 | 04:45 PM
Pro_built7's Avatar
Ms3 here,
don't know exactly what mpg she gets... but it's bad. Could be worse though
Old Aug 5, 2010 | 06:47 AM
69TA's Avatar
what is the cam specs on a MS4?
Old Aug 9, 2010 | 05:51 PM
NoGamesLS1's Avatar
I was able to get 24-27mpg highway nursing it with a t-rex in a 939ci motor (m6). I switched to a smaller cam (228-235) and my fuel mileage went down to 18-20. I believe that this is due to the volumetric efficiency of each cam. IE the smaller cam has a higher ve at lower rpm than the did the bigger cam. Higher ve means more airflow thus more fuel required to be stoich.
Old Aug 9, 2010 | 06:27 PM
That is incorrect. Airflow, from a normal driving perspective, is determined by the throttle body....that is how far open or closed it is.
Many things go into fuel mileage, but to keep it simple (because I am not educated enough to go into depth), engine efficiency is the key. And that all goes into the combo. An MS4 might make better MPG with a set of TFS 235s and a Super Vic then a smaller cam. However, that same "smaller cam" could make much better MPG with a set of 243s and LS6 intake then the same set up with an MS4.
Generally speaking however, a smaller cam with less duration and wider LSA will be better for fuel economy.
Old Aug 9, 2010 | 07:38 PM
KevinR's Avatar
.234/.242 .649/.610 on a 111, I think. I may be off a bit.
Old Aug 11, 2010 | 07:14 PM
SOMbitch's Avatar
.239/.242 .649/.610 on a 111, I think. I may be off a bit.
Fixed......
Old Aug 20, 2010 | 12:00 PM
chon79's Avatar
I'm getting 23-24 on highway, 14-17 city. And I definitely agree on these people that claim 29-30MPG on their huge cam setups - must be miscalculation. I have a T-Rex cam on M6.
Old Aug 22, 2010 | 01:07 PM
imma_stocker's Avatar
Old Aug 23, 2010 | 06:21 PM
jugz ss's Avatar
From my calculations I wouldnt even get passed 20 on highway and maybe 13-14 on st. I think the tune might have to do something with it as well. Might have to retune on partial throttle.
Old Sep 11, 2010 | 02:09 PM
shane_ss's Avatar
you guys ae making me not want the ms4 now haha i have a small 224/230 lsa 112 with a .591 comp cam and i get around 26 on high way and 18 in city i have a m6
Old Sep 11, 2010 | 04:54 PM
jimmyducati's Avatar
Agreed!! So that begs the question, why are people putting cams that are to big into engines that are not matched to support those cams?? I get about 28-30 on the highway (stock heads and cam) and don't expect it to decrease much (verified by my tuner in louisville) when i go with a well matched heads and cam package. if you match your components, have a sealed free flowing exhaust and a tune that is worth a damn there is no reason your fuel mileage should ever go down, unless you cant stop taking advantage of the new power...
Old Sep 11, 2010 | 05:43 PM
fccs's Avatar
+2 on this, although I don't want a ms4 anyways, if I was going to go big id go trex or polluter lol but anyways...
I get around 24-28mpg highway depending on how fast driving obviously and between 15-18mpg city depending on driving. Mods in sig
