Problems with the fuel system
Old Aug 3, 2010 | 12:06 PM
sway99bird's Avatar
Default Problems with the fuel system
Ok I have a LS1, PRC 5.3 heads, with SVO 30lb injectors, LS6 intake, stock fuel rails and a walbro 255 fuel pump. Problem is when I hit 5,000 + RPMS it falls on it's face, the shop I take it to is very busy at the moment to work on it so what do you think it is.........
Sway
Old Aug 3, 2010 | 03:35 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Get a fuel pressure gauge on it to determine if you have a fuel flow issue....
Let me know what you are seeing.
Old Aug 5, 2010 | 04:09 PM
sway99bird's Avatar
31psi um gonna replace the fuel filter specify I can get 58 psi after that
