need help with the wabro 340 install
Old Jan 21, 2004 | 08:23 PM
jrios's Avatar
Default need help with the wabro 340 install
I am installing the pump this weekend. I'm changing my fuel rail to corvette fuel rails with adjustable regulator. I would assume I have to remove my stock regulator. What does this look like? Anybody have any directions on how to do this??
Thanks for your help
Old Jan 22, 2004 | 12:19 PM
red ws6 99's Avatar
Stock regulator is the little round thing held in with the clip at the top of the sending unit. Yes you pull it out. There are many write ups on the board.
Gary
Old Jan 22, 2004 | 12:21 PM
Black LS1 T/A's Avatar
Moderator
This is a pic of the '98 fuel sender from that side the regulator is on:
I tried to zoom it in here:
The inlet from the top of the sender goes to the regulator and exits thru the dirty-brown accordion tube, which runs down to the bottom of the assembly.
This is a pic of when I did my dual-Walbro 340 mod.
Hope this helps!
Old Jan 22, 2004 | 01:00 PM
jrios's Avatar
thanks for the info and the pics now I understand.
Old Jan 26, 2004 | 10:58 PM
frcefed98's Avatar
Hey J, shot you a PM about your set up, shoot me some info about it,
Jeremy
