need help please...tank or pump leak
Old Aug 22, 2010 | 10:35 PM
408Maro's Avatar
Default need help please...tank or pump leak
Hey guys need your help asap please. I just picked up a 01 z last week has a few mods and also has a 255 racetronixs fuel pump with the hotwire kit. Assuming from what i read its the 99 model pump? The guy doesn't really remeber besides the 255 racetronixs part. Anyways it has dumped duals so i can see the tank and i just finished filling her up and brought her home and smelled pure gas so went to take a look under and noticed that the tank was wet under it like maybe it was seeping from the pump area? What's the chances the gasket isn't on right or that the tank has a hole? Anyone have this problem? Thanks guys want to get this fixed asap....please help
Old Aug 23, 2010 | 12:37 PM
408Maro's Avatar
Any thoughts? Im lost and waiting for racetronixs response
Old Aug 23, 2010 | 06:05 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Not sure what answer you are looking for. If you have a leak, you need to find the source, most likely by dropping the tank.
Could be a gasket, a leaking line or a problem with the filler neck. I doubt the tank itself is leaking.
Remove the under tank shielding & rock the car to see if you can get some fuel to spill & then follow the wet spot.
Old Aug 23, 2010 | 08:41 PM
408Maro's Avatar
thanks just got a email a bit ago from racetronix said almost positive its the sender gasket.. i siphoned all the fuel out and will drop the tank in a few days but after seeing it better i dont think its the tank..looks more from the pump or maybe neck but probally gasket
Old Aug 23, 2010 | 09:37 PM
408Maro's Avatar
also besides the gasket/ oring on top what else should i replace while im in there? thanks
Old Mar 23, 2011 | 02:52 AM
Duffster's Avatar
Raising old thread... what happened?
Old Apr 3, 2011 | 06:34 PM
408Maro's Avatar
sorry for late reply..old owner didnt put the lock on all the way so after wasted money and time all good now or at least i think havent drove it in about 8 months
