A1000 pump
1. Use a 5/8" pickup tube
2. Mount the pump level or lower than the bottom of the tank.
3. Maintain at least 1/2 tank of fuel at all times.
4. Install a check valve on the outlet of the pump to prevent drain back.
5. 12304 fuel filter on the suction side of the pump.
6. 10AN line from the pickup tube to the fuel pump.
Using the above guide lines will ensure your pump will live a long happy life.
