Intank AND inline?
Old Aug 26, 2010 | 07:42 PM
Gaunt's Avatar
Default Intank AND inline?
First off, I have a build going in to make roughly 850 rwhp through an F1A procharger. I will be methanol injected as well.
From what it looked like, I could choose from many kinds of fuel pumps to put in-tank and use the racetronix hotwire kit.
I am planning on doing two 255 lph in-tank pumps. Mainly inspired by the DIY Mighty mouse writeup.
The hot wiring kit looks like it is only for one fuel pump. Does racetronix have a solution for dual in-tank pumps? I realize some people wire their own stuff, but I have literally no knowledge in the area.
Second, more broad question. If I wired up only one in-tank pump now, could I add an inline pump later to meet my fuel needs? To add a little bit to the complexity, most people use a Hobbs switch that is boost regulated for a certain level of boost. I'm putting in the fuel system now to support the blower which is about a year down the road. Will that even work?
Thanks guys Yes I did search. No I didn't find a sufficient answer
Old Aug 26, 2010 | 10:23 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
An intank/inline combination is not the best way to go.
I have a dual pump solution complete with wiring harness if interested.
It is fully assembled & tested with plug-n-play wiring harness.
Feel free to call if I can be of assistance.
