Help getting my car running right
Old Sep 9, 2010 | 03:08 AM
CameronH117's Avatar
Default Help getting my car running right
Hey guys I've got a 98 z28 with ls1 it's got about 100k on her. Having problems with extended start and power loss. Originally I put a pressure gauge on it when the extended start started happening. My fuel pressure would jump up and then bleed back down almost immediately. It had a pump from oriellys on it that I swapped less than a month back for a brand new delco. It performed and started fine for a couple weeks then all of a sudden started the extended start again. I haven't hooked the pressure gauge up again to check for any bleedback yet. I also just replaced the maf sensor as I was told it could be contributing to the performance loss. The car will take a two turns to start. Also when I put it in drive and take the initial start of movement the car kinda sputters for a couple seconds then jumps right back to where it should be. Also my car accelerates about half as slow as when I had just replaced the pump. I also replaced the cats with high flows. O2 codes as well. Any help would be appreciated. I hate not having her at 100%
