Fuel injector recommendation
Old Sep 18, 2010 | 07:38 AM
SSZ's Avatar
SSZ
Default Fuel injector recommendation
5.3L with a MPt76 turbo. WIll run only gasoline. No E85 up here Dont know if i have to add any more info?
Old Sep 18, 2010 | 01:34 PM
Nasty N8's Avatar
What car is it in? what intake manifold? What are your HP goals? What is the fuel system consist of? Feel free to give me a call I will help you spec what you need.
Old Sep 18, 2010 | 01:52 PM
RibeiroBJJ's Avatar
8.1 Marine injectors (42 lb)up to 10 lbs of boost,with a walbro 255 intank pump
This is assuming you are running a truck intake and staying under 10psi
or 500 rwhp.....Worked for me, idc was at 100% above listed max numbers and stayed at 80% around 9psi 0r 460 rwhp iirc
-I would always run a little bigger though maybe some 60's..alot of variables
Old Sep 19, 2010 | 07:45 AM
SSZ's Avatar
SSZ
Thanks Nasty and Ribeiro. THe engine is in my 80 Z28. Stock truck intake. I run an Aeromotive A1000 fuel pump. Hp goal will be around 650 rwhp. Plan on upgrading intake to LS6 likely.
Old Sep 19, 2010 | 11:27 AM
RibeiroBJJ's Avatar
Definately go with 72 lb injecors...the 60's will have a hard time keeping up..You could always get a good meth kit to help out a little
