95lb injectors hp????
Old Sep 19, 2010 | 02:36 PM
camaroturbo's Avatar
Default 95lb injectors hp????
wut kind of hp will a 95lb injector handle with a twin 255 setup my log show that it flows 770 and no more am about 950 rwhp right now
Old Sep 21, 2010 | 07:26 PM
ZL1Killa's Avatar
www.rceng.com and click on technical page/link
I'm taking it you are turbocharged as your signature?
2nd question: what is your fuel pressure?
3rd question: What ratings of 95LB/Hr are you referring to? This would be at 3 bar (43.5psi) or 4 bar (58psi)
It can all depend on pressure. And also, do you have a Fuel pressure regulator, such that with MAP changes your pressure increases to "push" past the boost so that your actual injected fuel pressure is constant?
I will put it this way:
If you bought 94# injectors rated at 43.5psi fuel pressure & ran them at 58psi you would just about be running 80% duty cycle (basically ok)
If you bought 94# injectors rated at 43.5psi & ran them at 43.5psi .... well you wouldn't be ok.
Old Sep 22, 2010 | 09:56 PM
yes turbo car on pump gas fuel base psi is 43 the inj is 95lb at 43,5 I have a 1:1 reg and have not see the fuel psi drop on a run I use bigstuff3 to log it fuel psi gets up to 59 60 with 19.5 psi
Old Sep 26, 2010 | 02:01 AM
ZL1Killa's Avatar
anyway to log your current duty cycle?
According to the calculation you are about at your limit now for 80% duty cyle (Also assuming worst case too, but you are getting close to the limit it sounds like.
Old Sep 26, 2010 | 08:09 AM
Old Geezer's Avatar
@43.5 and 19.5, resulting in a pressure loss of 3, could be the pump[s] is running out of "breath"...
Old Sep 26, 2010 | 07:51 PM
yea duty cycle is 90 and i meet have to get some inj and put a 3rd pump on it thx guys
Old Oct 14, 2010 | 09:41 PM
ZL1Killa's Avatar
3rd pump... damn son... umm what two pumps are you running? they should be able to keep up with it, especially if you have a bosch 044 pump... two of those...
check out FIC injectors they have some large ones
