Fuel tank (HIGH PSI)
Old Sep 26, 2010 | 08:06 PM
MillsMotorvation's Avatar
Default Fuel tank (HIGH PSI)
Hi, I have a 1998 TA, and the car starts flooding, and missing, and sometimes wont crank! If you remove the gas cap there will be a lot of pressure on the tank, after the car cools a while it will crank!! What can cause this? I know the guy who owed it before installed a new, or bigger pump, think he may have messed up something?
Old Sep 27, 2010 | 09:06 AM
Anyone??
Old Sep 28, 2010 | 07:08 AM
Old Geezer's Avatar
Check to see if he messed w/ the tank vent.. Try driving w/ the cap loose and see if the problem repeats.
Check the fuel psi.
Old Sep 28, 2010 | 07:21 PM
Found the problem the canister tube that go to the intake was bent in a few spots, thanks for the reply!
