downgrade injector size
Old Jan 28, 2004 | 09:55 PM
HotRod68Camaro's Avatar
Default downgrade injector size
Im getting a 99 harness and PCM for my 98 engine which as far as i know has the stock injectors are on the car. my question is would i ahev to downgrade to the 26 lb injectors for any reason b/c thats what i was told.
Old Jan 29, 2004 | 11:13 AM
Nasty N8's Avatar
Or have the computer tuned for the 28lbs injectors. It will through the fuel curve off with the different injectors.
Nate
Old Jan 31, 2004 | 08:37 PM
Team ZR-1's Avatar
Stay with the 28s, your only talking like 2 lb difference and PCM will relearn and recal but best path would be to tweak the PCM injector flow table but it would run OK without tune
Old Jan 31, 2004 | 09:14 PM
what about if i used a 2002 harness b/c thats what i am now buying
Old Jan 31, 2004 | 09:20 PM
slow's Avatar
02 computer, and 98 injectors are within .2 # of eachother, and should compensate no problem.
Ryan.
Old Jan 31, 2004 | 09:23 PM
thanks for the info
