C5 fuel system
Old Oct 10, 2010 | 09:48 PM
LSOHOLIC's Avatar
Default C5 fuel system
Installing a plate(wet) system this weekend. Looking for info on a fuel system. C5 Corvette specific. 200 shot, wet plate and the motors already pushing 450(N/A) to the tire. Thinking I'm at the limit of the factory fuel system before the spray. Looking to DIY this, I'm on a budget. Thanks....
Here's kind of what I'm thinking. Walbro 255 in tank with a Bosch 044 external in line(would only like to activate when spraying, not sure how to accomplish that). After market rails with a regulator and return to the tank. How much would something like this support and how much would the total $ on parts be ?? Thanks...
Old Oct 11, 2010 | 05:03 PM
Nasty N8's Avatar
Its alot of parts and fittings to make something like that work properly. Dual intank setup is much simpler quieter and more reliable. And can be used with your factory lines to get the power levels you are looking at. Feel free to give me a call I will help you spec exactly what you need.
