will a l92 fuel rail and ls3 injectors work on a ls2 fast 102mm intake?
Old 10-10-2010, 07:57 PM
mike c.'s Avatar
Default will a l92 fuel rail and ls3 injectors work on a ls2 fast 102mm intake?
What it says. my bud has two different injectors for this l92 fuel rail. A set of stock ls3(they r short) and a long set i'm told are for a grand prix 36lbs. the fuel rail is on with the long injectors(had to use washers to space it up) and the car will not start. The fuel press goes to 50lbs then up to 70lbs when trying to start the car. Does he need ls2 fue lrails and injectors??
Old 10-11-2010, 05:08 PM
Nasty N8's Avatar
The FAST intake uses LS1 rails and tall inj. there are kits to mount LS2 to it.
The rails should have no bearing on the pressures. What car and whats the rest of the fuel system consist of?
Feel free to call I will help you get it straightened out.
Quick Reply: will a l92 fuel rail and ls3 injectors work on a ls2 fast 102mm intake?
