Ford 39lb Injector questions?
Old Oct 12, 2010 | 12:46 PM
Quick99TransAm's Avatar
Default Ford 39lb Injector questions?
I am maxing out my stock 28 lbs the are at a 105% duty cycle.So i bought some 39lb ford injectors and i ordered the ev6 connectors not the adapters my question is whats the best way to change the connectors out.Can i just remove the pins from old connector with the wires still attached and put into new connector or do i have to cut wire and use new pins.which the connectors come with new pins.
