Lookin for a Fittin
Ok I am looking for a fuel pressure test port fitting. I want one that is like 1/8" npt on one side and then the standard test port on the other. Any help locating one would be awesome thanks guys.
So you are looking for a T fitting to go inline off the rail end? all the test port fittings i have seen are 1/8" NPT. what do you consider "the standard test port"? are you talking schrader valve? if so, then you are looking for a fitting with 2 outlet ports, and i havent seen that, you could just put 2 fittings side by side though.
Ok I don't think I gave enough info I am runnin FAST rails and have one end capped. I want to drill and tap the cap, so that I can put a stock type schrader valve port in it. I am not sure but have heard that the LT1 or TPI have a screw in port.
