injector installation checklist
This is what I've figured so far:
1. Full ratchet set
2. Adj. wrench: to remove f/p gauge sender
3. Fuel line disconnect tool
4. Needle nose pliers
5. Masking tape: to mark wiring plugs
6. Oil: to lube the o-rings
7. Loctite
8. Rags
9. Step stool
t20 torx bit with a driver (to unscrew the fuel rail crossover)
socket and extension to unbolt the fuel rails and wiring harness (I can't remember which size)
o-ring lube
I disconnected the injector wire clips, unbolted the fuel rails, disconnected the fuel rail crossover, and then worked the fuel rails out with the injectors still in them and swapped them out. The passenger side is really simple while the driver side has a bunch of wiring and the alternator in the way. Just make sure the driver side is fairly clean if you try to work the fuel rail out through all of that mess. It took me a couple of hours when I put the 44lbers in and it took me half that time to put the stock ones back in.
Kyle
