Additives
Old Feb 2, 2004 | 05:56 PM
BADSZ28's Avatar
Question Additives
Should I run additives in my fuel? If so, how much and how often?
Old Feb 3, 2004 | 07:33 PM
buschman's Avatar
You know I went threw the same questions. What I came up with is that a water/alky system is a better way to increase octane. Additive $ can really add up. Not to mention you're using them when not in boost, which is money down the drain. Too much additive and you run the risk of damaging seals and fuel lines. The Water/alky injection kit is a much cheaper and easier way to regulate octane. Leats that's the conclusions I came up with.
Good luck bro,
Mike
