fuel cell how to and ?
right now i got duals 255 one on a hotwire one on a arming switch -8 line speed rails rail mounted fpr and stock feed as return but what i dont like is i got two pumps feeding into a 3/8 line to the stock sender to a adapter on top that goes to the -8 line big bottle neck right their wana get rid of that and have no restrictions for the new boost setup thanks
okay did more searchen found something about an aero stealth kit has the pump and universal sending unit inside the tank just hook up feed and return power the pump and go sounds slick anybody runing this can u tell me more
How much power are you shooting for?
Essentially you just need your same system but plumbed to a cell.
Typically the line between the tank & pump is larger, either -10 or -12 depending on the pump. The rest will probably be OK.
i am looking for a tank that can either be mounted in the stock location or in the trunk and preety much hook up my feed and run a new -6 all the way back for return and get rid of the stock fed as the return power the pump and go would like a 10 gal min 15 at the largest street car but dosent go on long trips so milage isnt a concern am i asking to much do u guys have anything like that do i need to call the shop for more info on the setup
do u have more pics how do u fill that tank i really like that stealth kit from with the pump inside but it wont fit nasty website dosent give good pics thanks
