Having Starting Problems
Old Nov 24, 2010 | 06:13 PM
spoolgoat's Avatar
Default Having Starting Problems
Ok, Here is the all my mods
Mod List:
T66mm Custom Turbo Kit
Aeromotive Fuel Rails
Aeromotive Fuel Reg
Lucas 75lbs injectors
New Spark Plugs
New Spark Plug wires
16gal Fuel Cell
Mallory 110 Fuel Pump
Running -8an lines on everything
The Problem I am having is the car will crank over and you can hear the Fuel Pump come on but its not starting. Only thing I change was the Fuel System, Injectors, Spark Plugs, and Spark Plug Wires. The battery is fully charged
Could it be the computer on the car is not reading the Injectors so it willnt start the car???
Thanks for the help
Richard
Old Nov 24, 2010 | 07:40 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
What does your fuel pressure read when you are trying to start the car?
Old Nov 29, 2010 | 09:37 AM
streetrodmuscle's Avatar
I am following this with interest, I just swapped a LS1 into my Camaro 72, and have done the harness conversion myself. I have +12V on the pink wires for the coils, and injectors. The fuel pump pumps up pressure and stops. and the engine cranks OK. I have deleted the VATS (antitheft) with a HP Editor. I still believe there is something that tells the PCM, not to start, because there is no spark at the plugs. Anyone who can tell me what sensors/parameters that will prevent the engine from starting? spoolgoat, we may have the same problem!
Old Nov 29, 2010 | 03:09 PM
LS1TECH Sponsor
Did you verify there is 12v at that connection during cranking? Certain 12v signals can go to 0 during crank.... be sure you have constant 12v.
