Rerouting Fuel Lines
Old Nov 28, 2010 | 08:06 PM
Turnin20s's Avatar
Default Rerouting Fuel Lines
I'm building a new exhaust and realized that my fuel and brake lines are shot, sucks having a northern owned car And on top of that I had some punk *** cut my fuel line on my car this summer
So my plan is to order some fuel rail and fuel pump adapters, couple of AN fittings (don't know which ones are needed yet), and some push-to-connect hose. Now as far as rerouting my fuel lines I'm thinking about running my fuel lines along the top of my trans tunnel by my ebrake cable. At least then they will be hard to cut, and they will be routed farther away from my exhaust than they are now.
So what are your thoughts about routing the lines like this? I'm also planning on relocating the fuel pump harness higher to avoid the exhaust. Brake lines will be run next to the fuel lines and drop to the axle in a little bit different location.
I'm going to be ordering the lines and fittings the first week of december, and I also need some sort of hose mount that will hold the 2 fuel lines and possible the brake line if anyone has any ideas
Old Nov 29, 2010 | 12:24 PM
Turnin20s's Avatar
Bump for opinions
